smart component box variables
Hi, I want to change size of box (or everything else) by changing variable in rapid. I was able to do it the value change but on the screen it did not change. thank's
1
francoisleclair said:Hi, I want to change size of box (or everything else) by changing variable in rapid. I was able to do it the value change but on the screen it did not change. thank'sHi,What version of robotstudio are you using?0
I think I have the same issu:
https://forums.robotstudio.com/discussion/13424/smartcomponent-parametricbox-does-not-work#latest
