Interrupt command not working
Hello everyone. The interrupt command that I use in my robot program only works once and does not stop the robot in subsequent signals. Although I deleted the interrupt command I defined with the IDelete command, I could not understand why it did not work.
I can't find where I made a mistake. Why do you think it might?
My main module on attechment;
  • Change the ISignalDI\Single,air_pressure,0,int_airpressure; to ISignalDI,air_pressure,0,int_airpressure;
    The interrupt is instructed to only run once.
