CoordinateFile Import Add-In
Hi! I'm trying to import some coordinate file data, with this Add-In but it doesn't work.
I have followed this instruction https://developercenter.robotstudio.com/api/robotstudio/articles/Walkthroughs/CoordinateFile-Import.html
The Add-In will appear under "General", it only gives option to "Autoload Add-In" and the "Load Add-In" option is gray. Using autoload doesn't do anything.
I'm using RobotStudio 2021.4 (64-bit)
  • lemster68
    lemster68 ✭✭✭
    When was that addin published?  It may no longer be compatible.  I played around with it some years back, it worked with older version of RS.
    Lee Justice
  • @lemster68 I can't find the data when was this Add-in published.
    I found discussions about it from 2012 to 2018. I'm trying to figure out, if I can make it work in newest version of Robotstudio.
