Using RobotWebServices to access a remote Virtual Controller
Maxim Riabichev
admin
WARNING: Performing the steps below allows access to the whole filesystem on the PC that hosts the VC and not only the files in the VC.
To access a remote VC with RWS successfully, please perform the following steps:
On the PC which is hosting the remote VC:
1) If it doesn't already exist, create a file called "vcconf.xml" in "C:\Users\{user}\AppData\Roaming\ABB Industrial IT\Robotics IT\RobVC\"
2) Put the following content in it:
<VCConfiguration><RemoteVCConfiguration PublicationEnabled="true" /><hosts><host ip="192.168.125.55"/></hosts>
</VCConfiguration>
3) Change the ip address (bold above) to the ip of the local PC from which you will be accessing the remote VC resources.
That should do it.
You're basically white-listing the IP of the client.
If you don't, you'll get either:
1. "RAPI Unidentified Error" when trying to access resources on the remote VC.
2. "401 Unauthorized" error if trying to access the VC via RWS.
</VCConfiguration>
That should do it.
Maxim Riabichev
PC Software Support Engineer
1
Perfect, I was just about to ask why it didn't work remotely! Thanks!//Markus Näslund0
Is it possible to white list multiple ip addresses?
1 -
Yes, it's possible to white list up to 10 IP's:
<hosts>
<host ip="10.11.125.1" />
<host ip="10.11.125.2" />
<host ip="10.11.125.3" />
<host ip="10.11.125.10" />
</hosts>
Wildcards are not supported.—Maxim RiabichevPC Software Support Engineer0 -
Hello Maxim
I don't have this directory on my PC when RobotStudio is installed ?
Neither "C:\Users\{user}\AppData\Roaming\ABB Industrial IT\Robotics IT"
Post edited by Maxim Riabichev on0 -
Hello JC,
Yes, if the path doesn't exist, it needs to be created and the missing file put into the necessary folder.—Maxim RiabichevPC Software Support Engineer0 -
Hi Maxim,
I followed your instructions and created vcconf.xml under RobVC. Still, the remote VC cannot be found neither by RobotStudio (2021.4 is used) nor by PCSDK. What could possibly be the problem?0 -
Hard to guess without knowing more details regarding your setup. Firewall maybe? Are you on the same subnet as the VC? Could be many reasons..—Maxim RiabichevPC Software Support Engineer1
I can get this to work for RW6 but this doesn't work for RW7. I'm getting access denied with https and the VC has error booting up with http.
Help please1 -
I'm running with the 6.15 controller, (also tried 6.13 and 6.14), but even with the
vcconf.xml file above (with the correct IP address of course), I'm not able to access the controller remotely, I still get the RAPI Unidentified Error message. I can access the controller from the windows system as localhost, so I know that RWS is running. I've tried rebooting, restarting the controllers, etc.
Please advise if there's anything else I can do.
Hi Matthansen,
At the beginning of the .xml, add <?xml version="1.0" encoding="UTF-8"?> if working on a WINDOWS system. For a LINUX system, use <?xml version="1.0" encoding="ISO-8859-1"?> instead.0
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 826 RAPID Programming
- 9 AppStudio
- 105 Collaborative Robots
