Creating Mechanism track
I am in need of a track with tavel length of 16.7m
The track is a RTT but the only standard length i RS is RTT 15.6
I have tryed using CREAT MECHANISM but i cant get it to work.
HELP HELP
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
  • Hi
    What isn't working???
    Per Svensson
    Consat Engineering
  • well when i go in to "create  mech" i have chosen External Axis.
    i need to specify links and doubleklik on LINKS.then i need to select a part and it is here it is difficult for me.
    A dont have any trackparts to select???
    I need the the track and the carriage but dont know how to find them??
    Kent Zibrandtsen
  • Hi
    If you go to
    www.abb.com/robotics and select
    Application Equipment & Accessories and then Track motion you will find 3d models under each type.
    Per Svensson
    Consat Engineering
  • hi
    i have tryed downloading the files For RS 5.07 but it is library files??
    Kent Zibrandtsen
  • Hi
    You should download acis files(*.sat) and import into RS.
    Per Svensson
    Consat Engineering
  • I cant see any Acis files in there.
    It is only RSlib-files theres in this location under RTT robotstudio 3_2 and RTT Robotstudio 5_07
    Kent Zibrandtsen
  • What type of track are you looking at exactly???
    Per Svensson
    Consat Engineering
  • i need a track a RTT marathon with travel length of 16.7 m
    Kent Zibrandtsen
  • Here is a RTT marathon including cfg-file modified to 16.7 m.
    2007-03-14_163402_RTT_16_7.zip
    ABB Robotics
