Cooling Fan 24V Part No. 3HAC025466-001
Hi All
Quick question.
Will it be possible to swop this non working cooling fan out with a standard 24V fan?
Will there be any issues if I swop this out? Damage? Errors? Functionality?
Quick question.
We've used other 24 volt cooling fans without issue.0
No problem with the newer IRC5, and on some older IRC5, an error many occur due to the tachometer monitoring signal.
