Error 40041, s4c+
kabhi19
There are 2 tool0 created and it's name is getting conflicted. Both are in read mode. I want to change it. How can I do that?
Is there a second instance of the BASE module installed? View tooldata and delete the extra one. Make sure that the values of the one that you keep are correct. It should be [0,0,0],[1,0,0,0]Lee Justice1
I'm not able to delete it from tooldata. It's saying read-only module 0 -
View modules, if you see a duplicate, delete one.Lee Justice0
- 363 IRC5
- 81 OmniCore
- 853 RAPID Programming
- 32 AppStudio
