Error 40041, s4c+
There are 2 tool0 created and it's name is getting conflicted. Both are in read mode. I want to change it. How can I do that?
  • lemster68
    lemster68 ✭✭✭
    Is there a second instance of the BASE module installed?  View tooldata and delete the extra one.  Make sure that the values of the one that you keep are correct.  It should be [0,0,0],[1,0,0,0]
    Lee Justice
  • kabhi19
    kabhi19
    edited April 2022
    I'm not able to delete it from tooldata. It's saying read-only module
  • lemster68
    lemster68 ✭✭✭
    View modules, if you see a duplicate, delete one.
    Lee Justice
