SmartComponent ParametricBox does not work
Hello together
I have a Problem i tried to generate diffrent Boxes with a Value from Rapid.
But there is always this Error: B1: property binding could not set 'SizeX' (value is above maximum)
For me it look like i can't set the size with a value, i also tried to set a value with a Expression but there is always this error.
Kind regards,
Nils
  • DanielWright
    Answer ✓
    Looks like it is trying to set the box as 245,000mm which is huge!
    you could try adding in an expression smart component with "A/1000" as the expression to convert it to mm.
  • anderer
    anderer
    edited May 2022
    Thanks i try this before but maybe I had a mistake, now it works!
