ScreenMaker : How to bind a ComboBox to a ProdData array ?
Luxrobotic
in ScreenMaker
Good morning everybody,
I'd like to bind a combox to a ProdData array.
I want to have all the String data which are the first position in my list in the ComboBox list.
How can I do this ?
Thank you
Regards
http://www.luxrobotic.com
Cornet Raymond
Manager
+352 621 354 570
raymond.cornet@luxrobotic.com
HP ZBook Fury 16 G11
Hello,anybody can help me ?Thank youRegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
http://www.luxrobotic.comHP ZBook Fury 16 G110 -
AFAIK it's not possible without custom .net component.Systemintegrator - Web / C# / Rapid / Robotstudio
Hello Tompanhuhu,thanks for your reply.What could be the alternative ?RegardsCornet RaymondManager+352 621 354 570raymond.cornet@luxrobotic.com
Hello everybody,
this is my mistake !
I extracted the string value of my ProdData array, and put it in a string array, and finally use a Listbox bound to a string array.
It works.
- 858 RAPID Programming
