how to make a perfect circle in mig welding ???
Small Zone parameters and also divide the segments into smaller pieces. I normally do around 9 points for a circle.0
It's helpful0
You could determine the center of the circle and then use that position, using offset moves to make a perfect circle. You could even make a routine that you can call with parameters such as robtarget and radius to use for the circle.Lee Justice1
- 858 RAPID Programming
