Is there an easy way to create a workobject 90 degrees perpendicular to the base?
Or to another workobject in the robot?
  • lemster68
    lemster68 ✭✭✭
    Use this:
      VERSION:1
      LANGUAGE:ENGLISH
    MODULE TCP_adjust
      VAR orient orient1:=[1,0,0,0];
      PROC tcp_orient()
        VAR num anglex;
        VAR num angley;
        VAR num anglez;
        VAR num nFKAnswer;
        TPWrite "This routine is use to calculate";
        TPWrite "The quaternions based upon EulerZYX";
        TPWrite "angles.";
        TPWrite "Remember EulerZYX goes Z rotation,";
        TPWrite "Then Y rotation,";
        TPWrite "and then X rotation";
        TPReadNum anglex,"Please enter the value for x rotation";
        TPReadNum angley,"Please enter the value for y rotation";
        TPReadNum anglez,"Please enter the value for z rotation";
        orient1:=OrientZYX(anglez,angley,anglex);
        TPWrite "Based upon your inputs,";
        TPWrite "Quaternion 1 is "\Num:=orient1.q1;
        TPWrite "Quaternion 2 is "\Num:=orient1.q2;
        TPWrite "Quaternion 3 is "\Num:=orient1.q3;
        TPWrite "Quaternion 4 is "\Num:=orient1.q4;
        TPReadFK nFKAnswer,"Press OK to Finish",stEmpty,stEmpty,stEmpty,stEmpty,"OK";
    ENDMODULE
    Lee Justice
  • lemster68 said:
    Use this:
      VERSION:1
      LANGUAGE:ENGLISH
    MODULE TCP_adjust
      PROC tcp_orient()
        VAR num anglex;
        VAR num angley;
        VAR num anglez;
        VAR num nFKAnswer;
        TPWrite "angles.";
    ENDMODULE
    Would this be entered into the main Procedure? And then just run the program from the Flex Pendant?
  • lemster68
    lemster68 ✭✭✭
    Just load the module as-is, then pp to that routine.
    Lee Justice
