Detect and remove UTF8-BOM Header
renehorstmann
edited June 2022 in RAPID Programming
Hey,
I am reading a text string from a .txt file in the HOME dir.
When I edit that file on the (real) robot controller in RobotStudio, it will be encoded in UTF8-BOM and the 3 byte header: "" is added at the beginning of the file.
What would be the best way to detect and remove the BOM header out of the string I read with:
VAR iodev io;
VAR string str;Open file,io\Read;str:=ReadStr(io \RemoveCR\DiscardHeaders);Close io;
my fear is that I can´t just have the string "" in the source code. Other UTF8 non ASCII glyphs (like äöü) are occasionally destroyed and replaced with other glyphs while saving/loading.
Thanks in advance
  • renehorstmann
    Answer ✓
    Fixed it,
    to not use non-ascii-glyphs in the source code, one can also use the hex representation of the BOM-Header like so:
    VAR iodev io;
    VAR string str;
    Open file,io\Read;
    Close io;
    ! remove UTF8-BOM 3 bytes header, if available
    IF StrPart(str, 1, 3) = "\ef\bb\bf" THEN
        str := StrPart(str, 4, StrLen(str)-3);
    ENDIF
  • lemster68
    lemster68 ✭✭✭
    edited June 2022
    Try IF str :=  "" THEN
            ! do nothing
          ENDIF
    Lee Justice
  • so are these glyphs "" ok to have in source code? "äöü" do make problems in our comments
  • lemster68
    lemster68 ✭✭✭
    If you were to try to view an encrypted module, you would see many strange characters, and so I could guess that the controller might be confused as to whether the module is encrypted or not with those characters present.
    Lee Justice
