One Mechanism --> two external axes
Anna
I am trying to repeat with RS 5.08 something I did before with RS 4.0 and I have a problem with it.
I have created a mechanism with two axes and I have made a library. I have two .cfg files to configure each axis, but when I add these parameters in the VC the program asks for two libraries!
I tried then to get the two axes description in one cfg file, but I cannot add this file to the VC, it crashes.
So, is there another way to do this with two cfg files or do I have a problem with this cfg file containing the two mechanical units?
Thank you very much for your help!
Anna
Anna2007-3-6 13:0:41Best Regards,
Anna
Anna
Hi again!
This problem will be solved in 5.09 version, so if anyone has the same problem...just patience!
Thanks!
Anna
Best Regards,
Anna0
