Web Services Backup Restore
I am trying to backup and restore (in this case a virtual robot) via web services.
Using postman I can backup the controller using the following URL
http://localhost/ctrl/backup?action=backup
Then if I gain mastership using
http://localhost/rw/mastership?action=request
And do a restore immediately with
http://localhost/ctrl/backup?action=restore
It works but for some reason if I don't for example do the backup first It fails and I get a 400 bad request.
Any Idea?
Thanks in advance
Gary
  • In actual fact I have discovered that the backup gets deleted after a restore...There is a parameter in the body of the request to not delete after restore and this works now.
    • delete-dir = {true | false} Indicate whether the backup directory should be deleted after the restore is finished. Defaults to true
