robostudio robotware 5.15
hello does somebody had a tuto to create a cell from a backup in 5.15
@lemster68 Could a tutorial on installing RobotWare versions that are not install-able from the apps tab be done?
I am not sure. Maybe. When it comes to the much older versions I just go with my older versions of RS.Lee Justice0
Copy the BootServer and RobotWare folders for the version of RobotWare you want to use into the Media pool folder located as shown below.
Then that RobotWare version will show up in the lists of available RobotWare version when building a system.
I had/have hit & miss success pasting 5.15 folders in the Media Pool. There is a possibility of corporate IS permissions being involved with items needing Admin privileges.
Also, I THINK the versions' installer file MIGHT be needed to add items to the Windows registry for proper RS functioning.0
