Rapid offline
Hi, is there some way one can test Rapid code offline?
If you want to program your robots offline the best tool is RobotStudio.
For IRC5 you should get RobotStudio 5.08
For S4 you should get RobotStudio 4
Per Svensson
Consat Engineering0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
