How to prevent someone add "VELSET" in my program
zin96
hi experts !
i wanna control my program and i don't want to let anyone add velset into it.
so what can i do , config the task or add trap routine
plz tell me and thanks so much
Hi Zin96,
Unfortunately I don't think there is any way to do this programmatically.
There is no value you can tie to an interrupt and no way to configure the task.
The only thing you can do is set up UAS on the controller so that the default user can't edit RAPID code and you have to login as a different user to edit RAPID code.
Good Luck,
Harry1 -
thanks, i have tried some ways but it doesn't work...Forge_Engineering said:Hi Zin96,
Good Luck,
Harry
tell me if u discover any way to deal with it.0 -
Hi Zin96,
UAS should definitely work if you remove access to edit RAPID code for the default operator or whatever they log in as. Do they still need to edit the program for any other reason?
Regards,
Harry0 -
If you have multitasking, create a new semi-static task with only thisPROC main()WHILE true DOVelSet 100,100;WaitTime 1;ENDWHILEENDPROC
1 -
I do believe that you would want the second number to be more like 5000.Lee Justice0
