set date and time on IRC5
Rookie
Hi All,
Did anyone found a way to set the date and time of the IRC5 by external equipment?
thanks
You should be able to set the date and time from a PC using the C# interfaces found in the PC SDK.The PC SDK comes with the RobotStudio distribution. To use it, the robot controller must have the "PC Interface" option.Steve0
Jep, found it.Thxs.0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
