Simulation Update Speed
I am using multiple line sensors in a simulated environment. Unfortunately, the outputs are only updating every 0.5 seconds or so, so all my search functions are hugely overshooting. I wrote an iterative search procedure to get around this by reducing the speed to basically nothing, but this still takes a long time. We're talking 12 seconds per point, best case, with low accuracy. Higher accuracy gets to 25ish. I've got a lot of points to pick up and my simulations are taking a long time to test which is significantly impacting my workflow and I know it is not representative of the real world.
What can I do to improve update times for simulated sensors?
@Maxim Riabichev do you have any words of wisdom here?0
Hello there,
I will look into this and get back to you.
In order to troubleshoot this issue we would need more data. Please contact your local ABB and ask for support, and provide a pack&go of the station.
Thanks.
