Rhino Geometry to RobotStudio
paultn12
I'm trying to find a workflow from Rhino 7 to RobotStudio 2022.
I am able to bring in .sat files (Solidworks option) as geometry, but I am unable to bring in curves. I am looking to create tool paths for different processes in Rhino and then ideally import them into RobotStudio.
Does anyone know a good way to bring curves into RobotStudio (file type/ programs etc)
Thank you in advance!
Paul.
Paul.
There are many different CAD formats RobotStudio can import .sat is the free one the others require a 'CAD convertor' license
I tried doing this once, and as long as the curve has a thickness > 0, it should be selectable in RS.—Maxim RiabichevPC Software Support Engineer0
- 304 PowerPacs
- 356 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 27 AppStudio
