RPC server is unavailable [WebWare SDK]
What is the reason, when there is the error message: THE RPC-SERVER IS UNAVAILABLE.
This kind error message appears using QuicTeach and Interlink Module in the same PC. I am using Visual Basic 6.0 ja WebSDK and I have built project for QuickTeach.
Matti Pitk?l?
Lamk / Tekniikan laitos
Finland
When you want to communicate with a Robot Controller you use RPC (remote procedure call). Which basically means that you are calling procedures in the robot controller.
When do you get this message?Have you defined a new alias in DCU (interlink) with ip adress 127.0.0.1 which you use in your WebWare SDK application
Per Svensson
Consat Engineering0
- 367 IRC5
