Create a Paint System from a backup. What is OleOS?
Kater
I received a backup from a customer to check the program of a painting robot. When I try to create a system from the backup I don't get very far. The "OleOS" is missing or has the wrong version.
I am only interested in checking the movement of the robot. The painting parameters/commands are not important.
My questions are:
- What is the OleOS?
- Can I get the system to run without OleOS?
My questions are:
Thanks a lot
Image: What is OleOS?
It looks like they are using some custom addin. You should ask them for it.
You mean a RobotStudio AddIn?To my knowledge, the robots were never used with RobotStudio. But i found a reference to "OleOS" in an ABB paper "Troubleshooting IPS upgrade in RW6 system".
https://library.e.abb.com/public/42680ee43a124d80ba93b3596d787067/Troubleshooting IPS upgrade in RW6 system.pdf
Maybe a tool, that someone used to upgrade old S4P Paint Programs and brush tables. I will try to get more information from the customer.Is there any way to manually remove the dependency from the OleOS and then create a control from the backup?thank you.0
- 361 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
