Rapid Encoder
Hello all,
I got a dos program from somewhere (can't remember) to encrypt Rapid code. The program needs 2 parameters: source and destination file and works great.
for multiple files ( I have 20ish) I would have to run that 20 times or create script.
So I wrote a small windows program to make it easy to encrypt 1 or n files and I would like to share it hear as small payback for the help I always get.
My only concern is that this means I distribute the original encoder.exe file and I don't know from who it is, who it owns and if this would get me into legal trouble.
If an administrator could help if there is any interest.
I think you can just specify a folder in the original encoder.exe, both as a source and destination.
And it will encrypt all files in that folder.Systemintegrator - Web / C# / Rapid / Robotstudio
Here's a copy paste from the encode manual.
Parameters:
encode takes two parameters:
sourcefile is the full path to the file, directory or tree structure to be encoded.
destfile is the full path where the encoded file(s) will be put.
Example:
encode –e –s –r –n c:\tmp\sourcefile c:\tmp\destfile
hahaha - classical case of over engineering then.0
Does anybody have the Encryption software ( encode) that works on W11 and IRC50
- 345 IRC5
- 71 OmniCore
- 843 RAPID Programming
- 19 AppStudio
