How can I write to Rapid Data by using PC SDK ?
Koyu
Hello all
I'm trying to write to Rapid Data (RobTarget) by using PC SDK.
I'm using 'Value' property and 'FillFromString()' method as in the code below.
However, if I do this, I will get this error:
C0048409 : An argument specified by the client is not valid for this type of operation.
RapidData rd = controller.Rapid.GetRapidData("T_ROB_R", "Module1", "Home");
IRapidData data = (RobTarget)rd.Value;
data.FillFromString("[[630.47,115.19,-65.24],[0.921282,0.346739,0.0368297,-0.172205],[0,0,-3,4],[-85.8249,9E+09,9E+09,9E+09,9E+09,9E+09]]");
using (Mastership m = Mastership.Request(controller.Rapid)) {
rd.Value = data;
I'm just a beginner of PC SDK that I might make mistakes in this code.
Would you tell me where I'm wrong?
Koyu
Koyu
2
I have not ever used it but I am taking a wild guess that the SDK ought to have the same datatypes as Rapid. As such, see if you have a robtarget datatype in the SDK and an equivalent function to fill from robtarget.Lee Justice1
Try reading this page
https://developercenter.robotstudio.com/api/pcsdk/articles/Manual/Using-the-PC-SDK/Rapid-domain/Working-with-RAPID-data.html
Hello.
Did you declare the robot target as pers? If it is const or var you will get this error message.
You should also use FillFromString2() as FillFromString() is obsolete.
—Nils OlofssonPC Software Support Engineer3 -
Thank you so much for your comments.
I declared the robot target as const, and after I changed it to pers, the writing went well !1
- 365 IRC5
