PP to Main
Hi, I'm trying to set pp to main (system input) from a screenmaker hmi, but im getting a boring message all the time:
"Event Message 20408, PP to Main rejected. The reason is that the write access is held by Default User using Flexpendant"
Must I create som sort of user to be able to reset the program pointer?
  • @Bjorn2 if you want to reset the PP via System Input the controller must be in automatic mode.
    In manual mode the system input cannot internally request the write access to perform the action.
  • Ok, thank's a lot! :)
