PP to Main
Hi, I'm trying to set pp to main (system input) from a screenmaker hmi, but im getting a boring message all the time:
"Event Message 20408, PP to Main rejected. The reason is that the write access is held by Default User using Flexpendant"
Must I create som sort of user to be able to reset the program pointer?
Ok, thank's a lot!
- 858 RAPID Programming
