RobotStudio connection with iPhysics (via PC SDK)
This software uses the PC SDK in order to communicate with the controller.
The RW version is the 6.14 and the PC SDK used by the software are the 2022.
Regarding RobotStudio what I have to setup in order to prepare it for the connection with a remote pc using the sdk?
Unfortunately the side of IPhysics is a "black box" so I cannot check the settings. When I try the connection I'm obtaining "not connected".
Thanks in advance.
"Regarding RobotStudio what I have to setup in order to prepare it for the connection with a remote pc using the sdk?"
What exactly are you trying to do?
