robAPI after updating RobotStudio from 2019 to 2022
I have used RobotStudio well till few days ago.
However, I have faced some issue on RobotStudio.
As the title, I updated RS from 2019 to 2022 that the latest version.
Then, I can't do anything through RS2022.
I can't create new station with backup file, and I can't not access to robot through one click connect with below error.
RobotStudio .NET exception: One or more errors occurred.
Base exception: AggregateException
at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
at RobotStudio.Services.RobApi.RobNetscan.get_Local()
at RobotStudio.UI.Controller.Commands.OneClickConnect.<Connect>d__5.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.<RaiseExecuteCommand>d__52.MoveNext()
Inner exception: AggregateException
at RobotStudio.Services.RobApi.Desktop.Transport.RobApiDesktopContext.<>c.<.cctor>b__2_1()
at System.Threading.Tasks.Task`1.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
Inner exception: COMException
클래스가 등록되지 않았습니다. (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
at RobotStudio.Services.RobApi.Interop.Win32.CoGetClassObject(Guid rclsid, CLSCTX dwClsContext, IntPtr pServerInfo, Guid riid)
at RobotStudio.Services.RobApi.Desktop.Transport.RobApiDesktopContext.<>c.<.cctor>b__2_0()
Unfortunately, I have to set up the robot tmrw....
Is there anyone who knows some solutions to solve this problem...???
I'd really really appreciate for it.
Thanks in advance,
Thanks in advance,
Dear All,
I solved above issue finally,
I had removed RS several times and reinstalled it in same directory(C drive), but it was still happend.
So I reinstalled RobotStudio in different directory and the issues was finally gone away (C drive to D drive)
