Modelling with different materials
Does a virtual controller change its performance when moving a load modelled with different material densities.
The model will be attached to an Atype positioner and I am wondering if there is anything in the signal analyser that can show a difference in performance when the positioner is moving models made with different materials.
Thought I would ask before I try ;-)
  • I think you have to apply a loaddata within rapid for the simulation to know the load & cog.
    If I helped, please press Vote Up  :smile:
