I cant save any station.
Today I installed RS5.08.
After that I cannot save any station including empty station.
The message says 'It may be no enough memory to store the data'.
The message also says 'unknown error to close the station'.
But I definitely have enough memory.
Could you help me?
Yu
Hello Yu,
When do you get the error, before or after the "Save As" dialog appears?
If you get an "Unknown Error" message in the Output window, please double-click it and paste the debug information here.
regards,
Johannes
Johannes Weiman
Hi Johannes,
It's after save as.
The "Unknown Error" is below.
RobotStudio .NET exception dump
Base exception:
The type initializer for 'ABBInternal.VstaServices.VstaIntegration' threw an exception.
at ABBInternal.VstaServices.VstaIntegration.UnloadAndRemoveStat ionAddins()
at ABBInternal.FileCommands.FileCommandServices.CloseStation()
at ABBInternal.FileCommands.CloseStationCommandHandler.CloseSta tionCommandHandler_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseE xecuteCommand()
Inner exception:BR
Yu
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
