path recovery after e-stop was triggered
Thank you Matti you are a hero !!!!matti said:Hallo, thats right. You have to use \singlesafe switch to have the interrupt working after a quick stop.But it will work only once, so you have to reconnect in the trap-routine.Your case is special, because you intend to go to a cleaning position after the e-stop.Usually you just continue bei pressing start. Especially when welding, the robot will perform a restart a little bit backwards automatically (if configured in the error handler).A description of the method you will find in Technical reference Manual-Rapid Kernel 3HAC16585-1, , Revision G
Controller software IRC5 RobotWare 5.12.0
- 365 IRC5
- 38 AppStudio
