Request: Translating Path in Painting PowerPac
Could it be made so that when translating a path in the Painting PowerPac the SetBrush events are also translated? As it is the ones that are the same direction as the path is moved are left behind and have to be manually dragged one at a time back into the path....
Hello there,
As Painting Powerpac isn't developed by the RobotStudio team, it'd be best to reach out to your local ABB with this feature request.
