RAPID, use a string to move the robot
I dont know if it's possible but i want to find the name of a robtarget and retrieve its coord. I already have the part to retreive the name but not to do the extraction of the x,y,z from the name in the string. Here's is my code
thanks.
MODULE armin_main
thanks.
PERS tooldata t10_pince_prise:=[TRUE,[[0,0,200],[1,0,0,0]],[1,[0,0,1],[1,0,0,0],0,0,0]];
PERS tooldata t20_pince_depose:=[TRUE,[[0,0,200],[1,0,0,0]],[1,[0,0,1],[1,0,0,0],0,0,0]];
PERS tooldata t30_ok_ouais:=[TRUE,[[0,0,200],[1,0,0,0]],[1,[0,0,1],[1,0,0,0],0,0,0]];
PERS tooldata t400_pourquoi:=[TRUE,[[0,0,200],[1,0,0,0]],[1,[0,0,1],[1,0,0,0],0,0,0]];
PERS wobjdata f10_machine:=[FALSE,TRUE,"",[[-1330.08,-1329.25,142.631],[0.381227,0.0805217,-0.0333532,-0.920364]],[[-3200,0,0],[1,0,0,0]]];
PERS wobjdata f200_table:=[FALSE,TRUE,"",[[-1330.08,-1329.25,142.631],[0.381227,0.0805217,-0.0333532,-0.920364]],[[-3200,0,0],[1,0,0,0]]];
PERS wobjdata f300_ascenceur:=[FALSE,TRUE,"",[[-1330.08,-1329.25,142.631],[0.381227,0.0805217,-0.0333532,-0.920364]],[[-3200,0,0],[1,0,0,0]]];
PERS wobjdata f40_retournement:=[FALSE,TRUE,"",[[-1330.08,-1329.25,142.631],[0.381227,0.0805217,-0.0333532,-0.920364]],[[-3200,0,0],[1,0,0,0]]];
CONST robtarget p10_target:=[[0,500,0],[0.500000092,-0.499999902,-0.499999987,0.500000019],[0,0,0,1],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
CONST robtarget p200_point2:=[[0,500,0],[0.500000092,-0.499999902,-0.499999987,0.500000019],[0,0,0,1],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
CONST robtarget p30_evitement1:=[[0,500,0],[0.500000092,-0.499999902,-0.499999987,0.500000019],[0,0,0,1],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
CONST robtarget p40_evitement2:=[[0,500,0],[0.500000092,-0.499999902,-0.499999987,0.500000019],[0,0,0,1],[9E+09,9E+09,9E+09,9E+09,9E+09,9E+09]];
PROC main()
!path_20;
VAR datapos block;
VAR string name;
!Found all TOOL to send
SetDataSearch "tooldata"\InTask;
WHILE GetNextSym(name,block \Recursive) DO
IF StrFind(name,1,"t")=1 AND (StrFind(name,3,"_")=3 OR StrFind(name,4,"_")=4 OR StrFind(name,5,"_")=5)THEN
TPWrite name;
ENDIF
ENDWHILE
!Found all FRAME to send
SetDataSearch "wobjdata"\InTask;
IF StrFind(name,1,"f")=1 AND (StrFind(name,3,"_")=3 OR StrFind(name,4,"_")=4 OR StrFind(name,5,"_")=5)THEN
TPWrite name;
ENDIF
ENDWHILE
!Found all POINT to send
SetDataSearch "robtarget"\InTask;
IF StrFind(name,1,"p")=1 AND (StrFind(name,3,"_")=3 OR StrFind(name,4,"_")=4 OR StrFind(name,5,"_")=5)THEN
TPWrite name;
ENDIF
ENDWHILE
Hi gdebeaudignies
I think you can use "GetDataVal" Which is documented in the RAPID Instructions, Functions and Data types manual.
Something like:GetDataVal name, \Block:=block, p_Temp;
That would store the whole robtarget in p_Temp.
Then you can access the x,y & z values individually through p_Temp.trans.x etc.
Hope this helps,
Regards,
Harry0
