RobotStudio .NET exception: The system cannot find the file specified
RS 2022.3.2, when trying to use the 'Go Offline' function or creating a backup of that controller..
Any ideas?
Below is the error message in full:
Base exception: Win32Exception
   at System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
   at System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
   at RobotStudio.Services.RobApi.RobServices.ExecuteProgram(String exeName, String args, String workingDir)
   at RobotStudio.Services.RobApi.RobServices.<>c__DisplayClass21_0.<DecompressLocal>b__0()
   at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at RobotStudio.Services.RobApi.RobServices.<BackupAsync>d__15.MoveNext()
   at ABBInternal.Transfer.GoOfflineCtrl.<ApplyAsync>d__17.MoveNext()
  • Hello CRom11,
    My recommendation would be to reach out to your local ABB with this issue, as the investigation would require access to sensitive information such as RobotStudio logs and so on.
    Maxim Riabichev
    PC Software Support Engineer
