[Request] Configuration View enhancement
DenisFR
DenisFR ✭✭✭
Can you add these some enhancement in Configuration list View?
1 - Save sort column: When you add/change system parameter, all are resorted and you are lost.
2 - Add Path and Attribute name in column Header: So you can access it using ReadCfgData
3 - Change Edit Window background color when you're not able to Write it: Or add a "Read Only" in windows title.
  • Hello Denis,
    Thanks for your suggestions.
    Can you please provide graphical representation of your suggestions? Like screenshots/paint drawings or something similar.
    Thanks!
    Maxim Riabichev
    PC Software Support Engineer
  • DenisFR
    DenisFR ✭✭✭
    edited July 2023
    Sorry, I miss type a word for 2. Column Header's Tool-tip.
    So for 1: Before changing Item
    After add/update item
    For 2:
    For 3:
    PS: Image insertion don't works!!! (FireFox)
  • Great ideas.
    FYI, its not Firefox, its a new annoying forum policy.
    David
    Swedish freelance ABB robot programmer
  • @DenisFR , can you please elaborate on the second point? You want the path and attrib. name added to the column just so you can read it ReadCfgData? Can you provide an example use case that needs this implementation (specifically via the column header)?
    Maxim Riabichev
  • Hello Denis,
    I ran this by R&D and here is the decision:
    Unfortunately, your 1st and 2nd suggestions will not be implemented.
    But the 3rd will! :)
    Maxim Riabichev
  • DenisFR
    DenisFR ✭✭✭
    Thanks,
    1rst is the most important to my eyes. It's really a pain to add signals...
  • Can you perhaps record a video where you show the problem and how you solve it? And how it becomes undone when you add a signal?
    A clear use case might sway R&D.. :)
    Maxim Riabichev
  • DenisFR
    DenisFR ✭✭✭
    edited July 2023
    After some times, here is the video:
    Post edited by DenisFR on
