[Request] Save Backup Location by System name
When I want to backup my robots, I have to carefully select Location as we have a lot of machines with each a folder.
It would be easier if the last backup location are saved in options file by system.
The drop down list should stay here but be initialized with saved location.
☑️2024 - RobotStudio® User Group
Hello Denis,
Can you please provide more information regarding this suggestion.
How does it look/work now?
How do you propose it should look/work?
Screenshots are appreciated!
Hello,I talking about Backup from RS in Controller Tab.When you click on it a "Create Backup from..." window appears.In which, you have a "Location" drop down list with latest folder used.With Virtual controller in station, it select by default the "station\User Files" (that's great)But with Online controller, it select the last you used.I ask for this selects the last you used for this current controller.☑️2024 - RobotStudio® User Group0
+1
Would be great.-----------------
David
