Omnicore C30 -- System inputs don't show
I have one controller Omnicore C30 witch comunicate with one Siemens PLC via Profinet interface.
I want to send to PLC, system signal PP to Main but on the I/O System Tab, doesn't appear System Inputs and System Outputs section.
How I can send to PLC this signal in this situation?
Thanks!
Thanks!
Check the controller tab.Systemintegrator - Web / C# / Rapid / Robotstudio
☑️2024 - RobotStudio® User Group0
