Setting Outputs via Robotstudio possible?
Braap
Hello guys,
i would like to set "Digital Outputs" via the Robotstudio "E/A System" to get a faster way to finish the IO Check with the PLC programmer.
Currently im always setting the outputs via Flexpendant by hand.
Is there a way to set the signal in Robotstudio without running the Robot with a rapid code "SetDO Signalname,1;"
If i want to set the Signal in "E/A System" i always get the error; C0048407: Operation rejected by the controller safety access restriction mechanism.
Thanks for your help!
https://imgur.com/a/r5U9RpE
Robotic Software Engineer
Got the Solution. Putting DO's on Access Level "ALL" instead of "Default"
Robotic Software Engineer0
This helped me today. Thank you for posting the solution!
- 367 IRC5
