DWG Import messing up the Scale
Siepen
when importing a .dwg file, RS is messing up the sizes and the proportions. In example im importing a Layout which scaling and measurements are good and working in Autocad, into RS it is suddenly 40x times larger and the proportions are messed up (lenght is good but width is suddenly x0.8).
Anyone has/had the same problem?
Hi, are you able to Export .stp files? I always get .stp files from our construction departement and this is always working fine in a 1:1 import.
Robotic Software Engineer0 -
in RobotStudio right click on the model/modify/scale gives you the opportunity to scale here
- 365 IRC5
- 84 OmniCore
