Description/manual page entry for own Proc/Func inside Shared Modules
I'm looking to create a sort of library for standard functions for our company to use in multiple robot applications.
I would like to make these inside a shared module, so all task can access these functions.
Since the software in a shared task is not visible in robotstudio, is there a way to:
Thanks in advance
- Show a short description when hovering over the function in light gray as "Update speed override for ongoing movement" when hovering over SpeedRefresh?
- Add a maual page entry so we can press F1 on a function to get its info?
Thanks in advance
bumpSystemintegrator - Web / C# / Rapid / Robotstudio
UP
Hello there,
Please elaborate on the second point. Who should be creating these manual entries, for which functions, and how should RobotStudio know that there is a manual entry for the given function? (or am I not understanding something?)—Maxim RiabichevPC Software Support Engineer0 -
Hello,1. RAPID code interpreter know where Func/Proc are defined. It can look one line forward if there is a comment block and use it.2. We can define a special comment Format in code to define which file to open like:!!HelpFile: /a_relative_path_to_help_file/helpfile.html#anchor_nameEDIT: And if RS can do like this MsCode extension:
Post edited by DenisFR on☑️2024 - RobotStudio® User Group0 -
Okay, thanks.
I'll run this by R&D and see what they say.—Maxim RiabichevPC Software Support Engineer0 -
This would be great.Systemintegrator - Web / C# / Rapid / Robotstudio
- 398 UpFeed
- 13 RobotApps
- 300 PowerPacs
- 405 RobotStudio S4
- 330 IRC5
- 66 OmniCore
- 824 RAPID Programming
- 9 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
