Virtual Controller - Save Rapid modules to Home
XNOR
XNOR
edited August 2023 in RobotStudio
In robot studio (2022.3) I'm finding the option to save modules loaded in Rapid back to the controller (HOME) isn't an option as "Save Module to Controller" is greyed out. Switching to manual mode didn't help.
Is this possible?
  • I guess you can find the VC on your pc and save - just a little indirect:
    C:[PATH]\RobotStudio\Virtual Controllers\[VC]\HOME\
  • It is not possible to use the option "Save to Robot controller" on a VC. It's only available when you are connected to the RC via RS.
