Running 2 positioners at the same time
Dear RobotStudio user,
How to run 2 positioners IRBP750L(or IRBP500R) at the same time?
Is there any mediapool to do that?
Boon Hua
Hello Boon Hua,
Here comes a mediapool and controller with the possibility to run 2 axis the same time. You can map 2 L positioners or 2 R.
2006-04-26_133607_3HEA50323088.dual_drive.rar
2006-04-26_133720_2400L_dual_drive.rar
Best regards / Henrik
I would like to run two positioners at the same time in Robotstudio 5.08. Where can I get mediapool? (I did not start new topic in RobotStudio 5.x forum, I hope it is OK)
Thank you,
Ziga
ziga2007-3-22 9:49:450 -
You should ask something about IRC in the column : "RobotStudio 5.x ( For IRC5 )" .0
