Wont load Modules Automatically
I start the main and send in the part but it will keep loading the same program instead of the one I want it to load. Any answers will help.
PROC LoadInitModule()
LoadModuleA;
ELSE
LoadModuleB;
Endif
EndPROC
I see an ELSE and ENDIF but no IF THEN. This should cause syntax errors. Have you posted ALL the code?Lee Justice0
This is what I got back from the Company that built the station
(ME) I noticed in the ProgramXFR.TXT it only has 2 modules in that which is the 2 that it will only run. I wonder if I must add the other grind modules into it?
(VULCAN Engineering) That file is written by the HMI. It should only ever have two lines in it. The first line is the module for side A and the second line is the module for side B. That is how the HMI tells the robot which program(s) to run.
I suspect that the HMI is not able to write to that file for some reason. That would explain why the robot is always running the same module.
!load module for the first time
IF bNoPartSideA=FALSE THEN
LoadModuleA;
ELSE
LoadModuleB;
ENDIF
PROC LoadModuleA()
!Load module for Side A
UnLoad ""\File:=ModuleNameA;
UnLoad ""\File:=ModuleNameB;
UnLoad ""\File:=CurrentMod;
CurrentMod:=ModuleNameA;
ERROR
IF ERRNO=ERR_UNLOAD THEN
TRYNEXT;
ELSE
TPWrite "Error In LoadModuleA Routine";
TPWrite "Error Loading Module to Robot";
TPWrite "Program Ended";
Stop;
ENDIF
PROC LoadModuleB()
!Load module for Side B
CurrentMod:=ModuleNameB;
ERROR
TRYNEXT;
ELSE
Stop;
ENDIF
PROC SpindleWarmUp()
Get_Tool_3;
PulseDO\PLength:=0.5,DO51_WarmUpReq;
EXIT;
Now I see more of your code. There is a bit of unloading that is unnecessary. All you really need it UnLoad CurrentMod. I don't see any code in which the actual decision making is going on to load which module. I suppose in your main program?Lee Justice0
This is the Main Module. Its supposed to read the module from the HMI, From the A side and the B side
Just cant figure out why its loading the same module no matter what I do.PulseDO\PLength:=0.2,DO27_StartMain;
ReadModuleNames;
TPWrite"ModuleNameA:"+ModuleNameA;
TPWrite"ModuleNameB:"+ModuleNameB;
Stop;
!Load Module for side A
LoadInitModule;
WHILE Di14_CycleRun=1 OR DOutput(DO07_Auto_ON)=0 DO
IF DI14_CycleRun=1 THEN
!Run the main Grind procedure
!from the loaded module
IF DI25_StaBinCell=1 AND bNoPartSideA=FALSE THEN
StationToGrind:=1;
IndexMainTable;
!process side A
Reset DO26_GrindingPrt;
CallByVar "MainGrindProc",GrindNumber;
!PulseDO\PLength:=1,DO26_GrindingPrt;
Set DO26_GrindingPrt;
IF bNoPartSideB=TRUE THEN
!Index main table if there is no part
!entered for side B
WaitUntil DI35_LgtCrtnOK=1;
IndexMainTable;
ENDIF
ELSEIF DI24_StaAinCell=1 AND bNoPartSideB=FALSE THEN
StationToGrind:=2;
IndexMainTable;
!process Side B
IF bNoPartSideA=TRUE THEN
!entered for side A
IndexMainTable;
ENDIF
ELSE
!The station outside the cell must be no part
!Index the table and wait for part ready
IndexMainTable;
ENDIF
ENDIF
Reset DO21_TbltoA;
Reset DO22_TbltoB;
ENDWHILE
This procedure call, ReadModuleNames; must have the logic for which module gets loaded by LoadInitModule.Lee Justice0
Okay I will check out the PLC Program and go from there I just needed to know where to start at this point.0
Hello,Take a look at bNoPartSideA values.And, what is wrote with:
TPWrite"ModuleNameB:"+ModuleNameB; TPWrite"ModuleNameA:"+ModuleNameA;
What are you meaning by this. I don't have many years of programming. We use this main module that was written by the company. I just build Grind modules.0
You should see text in FlexPendant "ModuleNameB:XXXXXXX".☑️2024 - RobotStudio® User Group0
Main Module had no file source to unload the program out of the robot and to load the system.
Old Coding
PROC LoadModuleA()
ERROR
TRYNEXT;
ELSE
Stop;
ENDIF
PROC LoadModuleB()
ERROR
TRYNEXT;
ELSE
Stop;
ENDIF
PROC LoadModuleA()
UnLoad "Home:"\File:=ModuleNameA;
UnLoad "Home:"\File:=ModuleNameB;
UnLoad "Home:"\File:=CurrentMod;
ERROR
TRYNEXT;
ELSE
Stop;
ENDIF
PROC LoadModuleB()
ERROR
TRYNEXT;
ELSE
Stop;
ENDIF
- 341 IRC5
- 69 OmniCore
- 840 RAPID Programming
- 19 AppStudio
