error while adding controller.
in OmniCore
I have installed latest version of robot studio (2023.2.1) but while adding controller to it showing error (There is error while starting the controller).
This problem is coming only while adding Omni Core controller (Robot Ware 7.10.0 & 7.10.1 both)
IRC5 controller (Robot Ware 6.15.03 &above) getting add and start without any problem only.
Hey, did u install the Flexpendant SxTPU4 also? I had this problem that the Controller wouldnt start up in Simulation without this addin.
Robotic Software Engineer0
- 363 IRC5
- 80 OmniCore
- 853 RAPID Programming
- 30 AppStudio
