Data type: anytype
Hi...
There is a possibility that I can pass an ANYTYPE parameter in one of my routines.
As RS does not handle method overloading, I would like to create a procedure where I can pass either a 'num' or a 'string' without having to use optional parameters.
Something similar to ValToStr() where: 'Val' is of type 'anytype'.
Thanks.
  • revans
    revans
    Answer ✓
    Sorry to be the bearer of bad news, but no you cannot. Below I have an exert from the RAPID Kernel manual.
    Note that anytype is just a marker for this property and should not be confused with a "real" data type. Also note that RAPID routines cannot be given anytype parameters.
