Addin: Double-click to center view
Tompanhuhu
Tompanhuhu ✭✭✭
edited January 2024 in RobotApps
Description:
Double-click in a 3D window to center camera view around clicked point.
The double-click must occur on the same selection object.
How to install:
Download rspak file, open Add-ins tab in robotstudio. Click Install and select package.
https://github.com/JETomi/TwRobotstudioDclickCenter/releases/tag/release
How to use:
Open Add-ins tab in robotstudio.
Right-click Doubleclick to center in the left panel.
Select load add-in.
If you want add-in to start automatically when robotstudio starts, select Autoload add-in.
Latest avalible version:
1.0.0.0
How to ask for support / feedback:
Write a post in this thread.
If I helped, please press Vote Up  :smile:
Post edited by Tompanhuhu on
  • Would you be able to link to the source code. I would like to modify it to work with a single middle click like some other software.
    Here:
