robotstudio 2023 deletes rapid from the virtual controllers
spg666
I recently installed the latest version of RS. When I open project created with RS 2022, I can get an error when the virtual controller starts. When the project is opened the contents of the virtual controller has been deleted. I've only tried this with 2 projects (both simulating omnicore controller). Don't know if it effects controllers using robot ware 6 as i didn't want to damage any more projects. anyone else has the same problem? or have a fix?
Hi...Check if when you save the project it gives a ''backup error'' message.I have a similar problem but for a normal controller and the RS is the 2023.
It may be that the project has already been saved with a problem.0
