Problem with the cone figure.
I have a problem. Since the latest update of RobotStudio 2023.4.1, it is not possible to adjust the reference points to the cone shape of the modeling tools. It happens to me and all my students.
1
Hello @J.C.M.Castillo,
Please reach out to your local ABB via https://new.abb.com/contact-centers with this issue.
Thanks!Best regards,Maxim
—Maxim RiabichevPC Software Support Engineer-1 -
I am seeing a similar issue... Can't snap to the point of a cone to create frame, etc. It is not a problem in RS 2022 (and previous versions) using part selection, snap object. The problem is in v2023.4.1. Any resolution?Here is a pack and go of the problem: https://gofile.io/d/WBOUYSPost edited by jerittwilliams on0
Hello there,
RobotStudio dev team is aware of this issue and has planned a fix for 2024.2 release of RobotStudio.
Can we know the expected date of this release?
There's currently no date set, but it's likely to be in June.
