variable Weavewidth in weavedata between 2 targets
Daper
Hello all,
Is there any way to increase the weave width between 2 targets using the ArcL instruction ?
For instance, start movement without weaving and at first target and reach the next one with a10 mm wide weaving ?
For those who may have the same question, It can be done using the ArcRefresh command within a timed interrupt1
- 364 IRC5
- 83 OmniCore
